broken bolt
I just got a t3 turbo and after closer inspection I relized a bolt had broken off on the exhaust side of the turbo. I believe its cast iron. does any one know where I can take it so they can get the bolt out? Or does any one on here know how to do it?
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
how big is the bolt and where are you located???? I have the tool to get it out if its not too small...... also if enough is sticking out try to double nut it.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
this is what it looks like. I live in town and country I will meet you if your not close. Thanks again for your help. There is any sticking out.
A machine shop should be able to do it no problem...I dont know of any around here, might check the yellow pages..Otherwise get a drill, punch and an EZ out, Might also need MAP gas. If you need help drop me a PM. I'm in new port richey.
AIM: SolderedLego
Toys are fun, atleast they dont say NO.
Like to drink buy a drinking tee
http://www.tampaforums.com/forums/mi...s-more-289609/
AIM: SolderedLego
InsaneCivicSedan clean your pm box
you fuckin troll. ban
