Sponsored by: CARiD
BOV Wanted
Old Feb 22, 2004 | 02:35 PM
king_johnthegreat's Avatar
Bukkake!!
I have a VERY new Godzilla BOV with a flange for welding into aluminum piping. It was installed for all of about ten days. I had steel piping, so that flange is toast; but the Al. one is brand new. PM me, if you like.
John
Old Feb 25, 2004 | 04:51 PM
BoostLogik's Avatar
BoostAddict
Not to hi-jack the thread, but personally I would look for an HKS if you want what is best for performance. The build quality is very good, (is a pull type relieve valve instead of push, so it holds boost and doesn't leak), has "bling bling" value over the others, and makes a really nice sound when venting. It also holds more power than the other comparable BOVs. (GReddy Type S, BLitz Supersound, APexi, etc.) The GReddy Type R and HKS Racing don't count as they are made for cars that are pushing much higher power. If you are pushing upwards of 500+ horsepower, I would possibly look into the HKS Racing BOV (which can handle up to 800HP by itself). The HKS Super Sequential is rated at around 450-500HP I believe. Alot of people will use two Super Sequntials instead of the Racing BOV on their higher horsepower cars. PM me if you have any further questions.
"Even through the darkest days, this fire burns, always"
Old Feb 26, 2004 | 07:33 AM
Sneakin Deacon's Avatar
PSSHHH x2
....how the hell do you rate a BOV for horsepower!?!?!?!?!?!
i can understand airflow...but horsepower?!
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Bukkake!!
Hey Dave,
I have the Godzilla up at the appt off Livingston, and will be available this evening when you get off work. I have it in the original box, with fittings and the aluminum flange. I also have all the aluminum pipe you might need to simply weld the flange up to either a piece of 2.5" or 3" charge pipe I had left over, as well. You could then simply put the piece in line with two couplings, if you choose. It is all yours, if you want it. Call anytime you like today; they gave me the day off (Unexpectedly)!
John
Old Feb 27, 2004 | 03:09 PM
BoostLogik's Avatar
BoostAddict
In terms of how much they are capable of holding. What the heck's wrong with you? You do realize the less expensive ones have weaker springs right?
