Sponsored by: CARiD
Another turbo question!
Old Nov 30, 2003 | 10:17 AM
mike34655's Avatar
Member
Default Another turbo question!
I am interested in purchasing a Garret Turbo for my 98 Integra GSR. What turbo should I go with in your opinion? I was looking at two of them. One of the two that I was looking at was the GARRETT T3/TO4E 57 TRIM W/ .63 A/R TURBINE and the GARRETT T3/TO4E 60 TRIM W/ .63 A/R TURBINE. Which one would be better for my application? Whats the difference with the 57 trim and the 60 trim? And at the top of the page it says,"OPTION: T3 5bolt TURBINE HOUSING", does this mean that I could make the turbo housing a 5 bolt downpipe? Thanks for your time and hope to hear from you soon. Thanks
Old Nov 30, 2003 | 02:24 PM
Nick's Avatar
Ridin dirty
That big of a turbo would it give you alot of lag. Or would it be responsive ??
AIM: Boost113
New best time @ Jennings 1:25.4
Old Dec 2, 2003 | 06:44 AM
Enthalpy's Avatar
TR Balla Donor Supreme
Mike.
T3/T04E:
Compressor : 50 Trim To4E, .60 A/R T04E housing
Turbine : Stage 3 T3 wheel, .63 A/R T3 4-bolt housing (actually TA31 Housing).
that is your best bet. make sure to get a 360 Deg thrust bearing. the 4-bolt housing flows better than the 5-bolt housing.
Old Dec 2, 2003 | 08:30 AM
mike34655's Avatar
Member
But with the 4 bolt can you still retain a/c? Because in florida you have to have a/c.
Old Dec 2, 2003 | 05:37 PM
99B16Si's Avatar
yes u can retain a/c. youll probably have to run a 2.5" downpipe like me tho. 3" is really hard with a/c
the turbo scott mentioned above will get to about 450whp and is a very well balanced turbo
