Sponsored by: CARiD
pressure drop question
Old Oct 20, 2003 | 11:42 AM
EclipseRSTurbo's Avatar
Default pressure drop question
hey guys, i got my FMIC in and the pressure dropped, i wwas wondering if the pressure will continue to drop because of winter coming and the air being so dense, or will the boost increase because the initial air going into the turbo will be denser?
Ya its an RS-T. they only make them in Japan
Old Oct 20, 2003 | 01:42 PM
Levi's Avatar
Or your wastegate is too small.
custom parts is our perfection.
Old Oct 20, 2003 | 03:00 PM
oh i forgot, the HRC kit came with a 5 psi wastegate actuator..................i have a 9 psi WA that i havent put in yet, would that solve my problem.
Old Oct 20, 2003 | 03:34 PM
Levi's Avatar
No, what you are seeing is 100% normal. Pressure drops from FMIC are normal.
You can make more power with a cooler charge, than a hotter charge. Just because your PSI went lower, doesn't mean that you are making less power. But seeing as you are now running a larger FMIC you can turn the boost up higher without overheating the charge temp..Its all just a heat game...
