Sponsored by: CARiD
Can my engine take this?
Old Oct 18, 2003 | 05:48 AM
F4A22's Avatar
Old School
Default Can my engine take this?
I'm runnin a custom turbo kit pushin 7 lbs as soon as 2500 rpm.I might be aquiring a dry nitrous kit soon on a deal i'm makin.I was wondering which is safer to spray on my intercooler or into my engine.If i sprayed into my engine(55 shot) i was thinkin get a secondary fuel pump and set my injectors to give it more fuel at the rpm i spray.Btw this a internally stock dohc zc motor.
Old Oct 18, 2003 | 06:53 AM
qitstrn's Avatar
Can you spot me 20 cars?
You were wondering what is safer to spray your intercooler or your engine? Come on! One gos in your motor, one does not. You be the judge.
Old Oct 18, 2003 | 10:55 AM
psifactor's Avatar
Hello
I'm not too sure of how much power a zc motor will handle but 7psi and a 55shot may be pushing it.
I'm sure keeping the ic cool with some n2o will make it more than happy. But for only 7psi thats probably not needed. I guess it also depends on your set up and turbo.
Spray the motor and see what happends!
Heavy car with a 2.5L
Old Oct 18, 2003 | 12:28 PM
NChatch's Avatar
i stepped on my weiner!
remember by sprayin your cooler you densify the aircharge, thus raising boost levels, when my neighbor was running 10psi, and sprayed his intercooler, the gauge read right below 13psi so be careful, the n20, and cryo spray companies tell you to lower the boost level before using thier product to be safe, if you make power that low in the rpm band, why would you need much more power, this is obviously in a crx, that thing should be hauling ass a 7psi?!?!?!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Oct 18, 2003 | 06:00 PM
F4A22's Avatar
Old School
yea i agree with ^ about sprayin through the i/c.They say zc's can safely do 200hp and from there ur pushin it.btw now i have fixed my boost leaks and need to actually find a way to lower my boost.It spikes to 10 lbs.
Old Oct 18, 2003 | 09:08 PM
EclipseRSTurbo's Avatar
92 CX hatch is a very smart man............i got a front mount intercooler and the pressure dropped about 2 pounds, very gay
Ya its an RS-T. they only make them in Japan
Old Oct 18, 2003 | 09:26 PM
722ish's Avatar
ASM FTW!
but you most likely make more power on less boost
95 Supra Turbo 6 speed
11 SWP STI sedan
Old Oct 19, 2003 | 05:00 PM
Strongest Man In The World's Avatar
Embrace the Hate
not about the PSI, its all about the CFM
CombatFitnessBlog.com
Click ^^ to receive the controversial Ebook "Maximize Your PT" for FREE
People fear what they don't understand, hate what they can't conquer. Guess it's just the fury of man!
Who are the Hardcore lifters?? StrengthCamp RyanMagin.com
Old Oct 19, 2003 | 05:27 PM
NChatch's Avatar
hey im just repeating what the instructions said in them, dont kill the messenger
owner/operator
