Sponsored by: CARiD
race gas VS pump gas??? tech
Old Oct 17, 2003 | 03:01 PM
NChatch's Avatar
i stepped on my weiner!
Default race gas VS pump gas??? tech
okay heres the question......
i was told that if you put race gas in your tank that it wont mix with regular gas because it is lighter than.....but i have put it in my car before and have notice the difference in the 2 gasses. so what is the truth with race gas...
also when does it become too much octane?? 104,110,116???
what is good to run on a turbo honda to run 15 psi on a decently built motor?
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Oct 17, 2003 | 03:49 PM
Sneakin Deacon's Avatar
PSSHHH x2
race gas is pretty much meant to get rid of detonation/pre-ignition.
the flashpoint gets higher as the octane rating raises.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Oct 17, 2003 | 04:43 PM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Default Re: race gas VS pump gas??? tech
What exactly did you notice? Less power when the race gas was being run?
Old Oct 18, 2003 | 12:21 PM
NChatch's Avatar
i noticed better throttle response and quicker acceleration, but with my supercharged crx, the guy at the dyno told me that sometimes you can have too much octane and net less HP because your motor cant ignite the mixture, if it is too high?????
owner/operator
Old Oct 18, 2003 | 12:24 PM
NChatch's Avatar
that chart is great but it doesnt tell you at the top of the table what gas you are mixing in to get the figure, i dont understand, maybe im a tard, but can someone explain,
owner/operator
Old Oct 18, 2003 | 12:47 PM
Well you make less HP from higher octane thus, the lower the octane, the more power you make. Octanes are only used to prevent detonation, so you want the lowest octane possible without detonating.
Old Oct 18, 2003 | 12:58 PM
99B16Si's Avatar
basically your car needs to be tuned to run race gas efficiently. just dumping it into a car tuned for pump gas in most cases will cause it to lose power. when race gas is added, it allows the igntion timing to be a little more agressive thus making more power. also leaning out the a/f ratio a bit will also help make more power
