Got My Blitz SBCID Boost Controller Today
Guest
Posts: n/a
Being new to the turbo stuff I will have my work cut out for me on this unit.
Here is the info.:
• 4 boost settings, scramble boost, warning and limiter, peak hold and digital boost display
• SBC i-D can work in conjunction with Power Meter i-D via infrared connection
• Able to choose boost measurements (PSI, BAR, Kg/cm2, and KPA)
• Sequential dual solenoid design for better boost response boost display in both digital bar and graph
• 1/2 din size (15mm thick)
• direct boost settings
Here is the info.:
Its funny with all the features this thing has, I dont really change them ever.
In my situation, I've had best results setting the warning limit just above my target boost, and pushing boost as close as I can to that limit. Seems to create the straitest line out of all my testing.
Oh and fwiw.. dont set the warning duty cycle ABOVE the boost duty cycle your using, it doesnt work well.
Ian
Syclone | CRX si | Mazda3
Ian
That's a bad ass boost controller. If you ever need the instructions in Engrish let me know. I have the same controller but I have yet to put it to use. One day I will! Keep us updated on how you like it.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Guest
Posts: n/a
PM me and I will send you the fax #.
Thanks
