Gauges
Guest
Posts: n/a
EGT is far better and more meaningful than an A/F gauge. ANY A/F (yes, even the super cool dori dori drifo JDM ones) is a meaningless light show unless it comes with a wide band O2 sensor. If it costs less than $500, it doesn't come with a wide band O2 sensor.
Some of you guys are wrong... real wrong
EGT is worthless, it tells you how hott you are... thats it. What makes it worse, is it tells you how hot you WERE 2 seconds ago... Its like "Hey, you hit 1680*F back there... oh and by the way, your #4 piston is melted.... " thats what they say. You cant tune reliably on an EGT guage, there are too many variables. I know too many people who have blown up supras, scoobies, RX7's and DSM's cuz their EGT's SAID they were at an acceptable temperature... but something went wrong and dont know what happend
the GReddy "Wide Band" O2 guage is not wide band. its only a 4 wire sensor... its a "medium Band" at best, if not simply a "Narrow Band". In order to be a REAL UEGO Wideband guage, you need to have AT LEAST 5 wires, if not more. the GReddy "wide band" is a analog-style version of the Autometer A/F-Blinky-ricer guage. Narrowand only works on 0-1v and does not give you enough precision, there simply not enough steps between 0 and 1 volts to register an accurate A/F readin, unlike the 0-5v: there are 5 times as many steps and can give you a more accurate reading.
Its like the difference between a 12:1 reading and a 12.35:1 ratio, know what i mean?
A Blinky A/F guage is worthless... it basically just tells you "hey your rich" or "Hey, youre lean" but it doesnt say if your 11:1 rich or 12.5:1 rich... get what im sayin? half-a-point makes a HUGE difference.
Ryde has got a handle on things, especially when it comes to FC's: one of THE most important aspects of monitoring a Rotary is the coolant temp. If they get too hot, even ONCE, youre toast and need new O-rings.
youre gonna run a speedo, tach, and water temp guage? or your going to run boost, oil pressure and EGT?
Lets hear some input as to why youd select these guages over the others. I just put a GReddy 52mm 1.5Bar boost guage in my supra cuz my stocker is not even mechanical... its an electrical that is actuated by the Airflow signal from the ECU and is not accurate at ALL... the factory boost guage simply lets you know IF you are boosting, but not how MUCH... see my problem was, me smoking an LS1 camaro and my boost guage TELLING me i was running over 8psi.. when i put in my GReddy guage, it said i was only running ~0.5Bar.... and im like WTF, peice of shit stocker.
seriously...
Originally posted by 99B16Si
id say boost, oil pressure, and egt are the most important. unless youre using a wideband an A/F gauge is worthless. and if your car is tuned then its even more worthless. most cars come factory with a speedo, tach, and water temp which are usually sufficient
I would agree with Dave, Those are the gauges that I am going to be running..
seriously...
AEM is ghey... its a cheap rip-off of the Pro-EFI system that has been around for YEARS... and is better than the AEM-version of it.
I had a friend who put a Built H22A into his 99 Accord 5speed w/ a 60-1 T3/T4... it took him FOREVER to install it... and 2 hours to just toggle the fuel pump on and OFF... yea... AEM is better
If youre going thru all the Hassle... you should run a Hondata if you have a Honda... its tried and true. why try to reinvent the wheel and one-up the next guy. go with what works, trust me.
and you can get a DIY-WB02... a full Laboratory-grade UEGO Wideband setup for ~$450, including a LED Numerical Display (think, huge calculator screen w/ Red numbers) and it reads into the tenths... 13.8:1 ?
Thats what i'll do run hondata so i can sit on the dyno burning chips all day.You can update AEM anytime.Hondata was the shit years ago get with the program it's 2003 where have you been!
I guess I am simple. I will be using a boost and egt gauge (two gauges in one).
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Guest
Posts: n/a
Either way, neither an EGT or wideband will help you tune, they will tell you what they see, and its entirely up to you to interpret and change accordingly.
An EGT gauge is not for dummies, you must know what the gauge is telling you and what to do to correct it. Its not perfect, but there's nothing better. If you think top tuners are only tuning by coolant temp then you are sorely mistaken. Any tuner that knows what the fuck is going on is tuning by either wide band or EGT. Since EGT's are cheaper and not sensative to leaded gas, the EGT's win out for "budget" oriented systems.
when an UEGO sensor is installed, it is far downstream of the engine, but, there is more forwarning and a little more lee-way. Id say that the UEGO WB02 values are the 3rd most important factor to consider. at least this guage can react quickly due to the electrical signal
the 2nd most important factor to consider when tuning is total ignition timing advance. the amount of total timing will vary from car to car. So its your job to know how much is too much. Like the DSM, 16*total on WOT is accetpable during Initial WOT tip-in and you want to shoot for 21*-22* total timing @ 7500RPM WOT.
the 1st most important factor is the knock sum... if you have a way of monitoring it. DSM's do
I prefer to tune for a 0-3 knock sum, I beleive its measured Per second. but, unfortuantly, not everyone can tune by ignition timing advance and knock counts... so they have to resort to secondary methods such as A/F ratios and EGT's.
btw, no one was saying to tune by coolant. I was saying that the coolant temp is VERY important on a Rotary motor, they are more sensative to overheating than any other car out there. So on a Rotary application, i would rank a race-quality coolant temp guage right up tehre w/ the rest of those tuning guages.
Oh, and theres no need to be rude or vulgar about this, we are having a nice mentally stimulating conversation... so calm the fuck down and watch your fuckin mouth
EDIT: i forgot to mention... if anyone thinks they can afford >5 hours of dyno tuning, they can afford a UEGO O2 setup. tahts my justification: "do i spend $125 per hour on the dyno, or do i spend $450 upfront and have access to dyno-quality tuning whenever i go for a ride???" Hmm, ill squander the money upfront and be able to tune at my whim later on down the road and get more for my moneys worth.
