Sponsored by: CARiD
gutting a cat on a turbo
Old Aug 26, 2003 | 10:20 AM
20v vdub's Avatar
Default gutting a cat on a turbo
I herd from some friends that i should gut my cat on my car..Is there benifits to this?i also have sensor in the cat.....good idea or not....
Old Aug 26, 2003 | 12:06 PM
EclipseRSTurbo's Avatar
it might create more boost since there is no exhaust restriction, i'm not positive though.
Ya its an RS-T. they only make them in Japan
Old Aug 26, 2003 | 01:14 PM
The Kyle's Avatar
Captain Catastrophe
it wont "create more boost" but it will free up your exhaust a bit....although i recommend getting a test pipe to REPLACE your catalytic converter instead of just yankign it and gutting it...get a test pipe, through your cat in the garage some where just incase you might need/want it down the road for some odd reason.
my .02
Old Aug 26, 2003 | 02:31 PM
why don't you just go open down pipe and not even waste your time with the cat
Old Aug 26, 2003 | 03:46 PM
BoostedRS's Avatar
I can freeze time
With my testpipe, I noticed:
1. faster spool up
2. more power on mid-top end
3. lower EGT's
Bad thing is that it stinks, and i had once a scare when 2 cops in a bike was sitting right behind me on traffic, smelling all that crap
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Aug 26, 2003 | 05:59 PM
20v vdub's Avatar
my cat is attached to my down pipe,I ran it open this weekend and saw a difference even though the exaust was still going though my cat...I guess i could just replace the cat with a pipe,and later if i needed i could replace the cat...Allso there is a sensor in my cat if its remove will my car still run good....Thanks
Old Aug 26, 2003 | 06:15 PM
flubyux2's Avatar
Elitist Supra Asshole :)
is there an O2 sensor mounted in or after the cat or not? if there is, and you remove the cat, your ECU is more than likely gonna throw a CEL and possibly put you in limp mode.
Old Aug 27, 2003 | 09:07 AM
ReDsM's Avatar
"Owell"
ya thats why mine is waiting i did sensor-back exhaust instead of catback
TRYIN TO RIDE "CLEAN"
Old Aug 27, 2003 | 12:41 PM
20v vdub's Avatar
my sensor is in my cat...so its probely not a good idea then...Thanks
