Flywheel & Boost
Pros and Cons?
I wouldnt be getting one now, but eventually I'd like to know whether it is worth it or not (or lightening the stock flywheel).
I have heard that some of them are too light and will cause the motor to drop out of boost or powerband during hard straight line acceleration. However, I do see many cars running it and is there a certain power level that would best benefit from getting one or keeping a heavier one.
A major 240 company called Enjuku makes a lightweight one piece aluminum driveshaft for us, I will most definately be getting that soon, as I hear it will allow the quicker revs but wont have the apparent drawbacks of the flywheel.
Any thoughts on this subject?
My setup will eventually be ~350rwhp on stock 2.4L motor which means gobs of torque. The car is an occasional 400m track car, but mostly street car for fun nights on the town. I do not plan on shifting the powerband beyond the stock limits at this time, only the addition of earlier model stock camshafts will provide some breathing relief between 5500-6300. ECU change later on would bump rev limiter to 7000rpm, which would be the limit for me. I would most likely start out with clutch, aforementioned driveshaft upgrade, and an LSD upgrade, as far as drivetrain goes. Would a lightened flywheel be worth it? (The one in question runs $330)
Guest
Posts: n/a
1f y0u l1k3 70 d|21f7, g37 0|\|3
1f y0u l1k3 70 74k3 7\^/157135, g37 0|\|3
1f y0u l1k3 4 f457 |23vv1|\|g c4|2, g37 0|\|3
1f y0u 4|23 u51|\|g 4 5l1pp4bl3 clu7ch, g37 0|\|3
1f y0u 4|23 g01|\|g 70 b3 57uck 1|\| 4 l07 0f 570p 4|\|d g0 7|24ff1c, d0|\|7 g37 0|\|3
1f y0u 4|23 g01|\|g 70 b3 l3|\|d1|\|g 7h15 c4|2 70 y0u|2 m07h3|2 0|2 07h3|2 1mp0|274|\|7 p30pl3 \^/h0 4|23|\|7 c4|2 3|\|7hu514575, d0|\|7 g37 0|\|3.
1f g45 m1l34g3 15 v3|2y 1mp0|274|\|7, d0|\|'7 g37 0|\|3.
1f y0u 4|23 g01|\|g d|24g |24c1|\|g 0|2 57|2337 |24c1|\|g 0|\|ly, y0u \^/4|\|7 50m37h1|\|g m1d \^/4y b37\^/33|\| 7h3 ul7|24 l1gh7 \^/31gh7 0|\|35 4|\|d 7h3 570ck3|2. M455 15 1mp0|274|\|7 0|\| 7h3 l4u|\|ch.
P3|250|\|4lly 1 \^/0uld g37 0|\|3 bu7 1 c4|\| b3 4 b17 0f 4|\| 3><7|23m157
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by 3|\|7h4lpy [/1]
1'v3 h34|2d y0u 73ll 07h3|2 p30pl3 7h15, 4|\|d |\|3v3|2 qu173 g|245p3d 7h3 1d34, c4|\| y0u 3l4b0|2473? [/QU073]
7h15 15 \^/h47 1 |234d 4|\|d 17 m4d3 53|\|53 70 m3.
M455 c4|2|2135 3|\|3|2gy. 7h3 m0|23 m455 y0u h4v3, 7h3 m0|23 3|\|3|2gy 17 c4|\| c4|2|2y.
7hu5 1f y0u h4v3 4 h34vy fly\^/h33l, 0|\|c3 y0u 4cc3l3|2473 17 up 17 70 5p33d (c|2u151|\|g), 17 c4|2|2135 7h3 3|\|3|2gy. 4 l1gh7 fly\^/h33l d035|\|'7 c4|2|2y 45 much 3|\|3|2gy, 7hu5 y0u mu57 c0|\|574|\|7ly |234cc3l3|2473 17 70 m41|\|741|\| v3l0c17y.
0f c0u|253, 7h15 15 f0|2 h1gh\^/4y d|21v1|\|g. 4|20u|\|d 70\^/|\| 17 \^/0uld 4c7u4lly b3 7h3 0pp05173.
7h1|\|k 0f 7h3 fly\^/h33l5 l1k3 b0uld3|25. 0|\|3 \^/31gh5 200lb5 4|\|d 0|\|3 7h47 \^/31gh5 50lb5. 1m4g1|\|3 7|2y1|\|g 70 pu5h b07h 0f 7h3m 70 45 f457 45 y0u c4|\| (4cc3l3|24710|\|). 0bv10u5ly, 7h3 50lb b0uld3|2 15 g01|\|g 70 b3 34513|2 70 pu5h. |\|0\^/, d0 7h3 54m3 7h1|\|g bu7 0|\| 4|\| 1|\|cl1|\|3, 4|\|d 570p pu5h1|\|g 4f73|2 y0u 47741|\| 4|\| 3qu4l d351|23d 5p33d 0|\| b07h. \^/h1ch \^/1ll |20ll fu|27h3|2 4f73|2 y0u 570p pu5h1|\|g? 7h3 h34v13|2 0|\|3, |21gh7?
F33l f|233 70 4|2gu3 7h15 p01|\|7.
Guest
Posts: n/a
Originally posted by JJFreshyZC
Would the same apply to a front wheel drive car, i.e. B18 Turbo? Any difference since the car is "pulling" the weight rather than "pushing" as with a rear wheel drive car? Just a thought..
Jay
Jay
-Keith
thanks for the replies.
i forgot to mention the 'falling out of boost' part was what i had heard and never had it confirmed. plus i figured it shouldnt have made much difference if it were true.
i will probably get one down the line, the fidanza 11lb one is pretty much the main one for the ka motor (stock ~21lbs) but not as light as some of those 8 and 7lb jun flywheels for other cars so i figure it will still be a daily driveable clutch. coupled with a spec stage 3 (or 4 later) and the driveshaft/lsd/nismo slave and ss line combo, i figure it will be a fun setup. i, like, john, am also an extremest...well only in plans so far. i have yet to reach the amounts of money to prove that yet hehe.
thanx again
thanx again
