upgrades all at once?
as many of you know I am putting together a turbo system for my b16 motor. I want to do as much of the work as possible myself, mainly because I have custom ish and every time I take to some one else it gets f'd up. My question is can I install the fuel pump (walbro 255lph) aem fuel rail, aem fpr, and 450cc injectors before throwing in the hondata, if not which parts can I put on? my main issue is with the fuel pump since where it goes is right under my amps for my stereo and that makes for a mess of wires.
also does anyone know which car I need to order the fuel rail and fpr for. I.E. 99-00 si, 94 del sol vtec dohc, the b16 is obd0. thanks
Guest
Posts: n/a
you can do it all but the injectors... and the fuel rail should be the same part # for both... if you put the injectors on with nothing to control them your car is going to drown itself... might run but she will be RICH... so wait on those...
-Keith
-Keith
