Power Adders FS and WTB Got a turbo to sell? How bout a boost controller? Post it here!
Hks Bov
Old Jun 23, 2006 | 05:21 PM
Country Boy's Avatar
can survive...
Default Hks Bov
HKS Racing BOV $150 shipped
Only has <100 miles. HKS Racing Bypass valves are push type valves that utilize calibrated spring pressure and vacuum line pressure to remain closed against the pressurized air in the charge pipe. As the throttle is closed, creating vacuum in the line, combined with the force of the pressurized air in the charge pipe, the bypass valve pushes opens and allows the pressurized air to escape. The HKS Standard Bypass Valves are adequate for the airflow. HKS Racing Bypass Valves function similar to the Standard Bypass Valves, but incorporate an additional pressurized port to aid under severe boost conditions. The Racing Bypass Valve can also be used as a safety "pop-off" valve if the second port is connected to a pressure source that does not see vacuum. For added flexibility and function, HKS Racing Bypass Valves are offered in various adjustable boost pressure ranges that are determine by a specific spring pressure.
[IMG]http://img.photobucket.com/albums/v614/01NastySS/My%20car%20and
Old Jul 23, 2006 | 08:51 AM
turbo-max's Avatar
The G-14 Classified
ttt, for the the homeboy
Boost...it's a hell-of-a drug
Old Jul 25, 2006 | 02:52 PM
can survive...
thanks brah! Someone buy this thing!
