Hypertherm Extreme Bevel Plasma Consumables for MAXPRO200 Air and Oxygen Plasma Syste
Hypertherm Extreme Bevel Plasma Consumables for MAXPRO200 Air and Oxygen Plasma System
Hypertherm has announced the release of extreme bevel consumables for its MAXPRO200 LongLife air and oxygen plasma cutting system. The consumables, designed for mechanized, robotic and handheld cutting, have an aggressive pointed geometry so the plasma torch can tilt to an angle of up to 66.5 degrees. This makes the consumables ideal for a wide range of jobs, including steep mechanized beveling, tube and pipe cutting, structural steel work, pressure vessel construction, and handheld cutting. In addition, it makes it easier for operators to see what they are cutting and gives them better access to beam flanges and areas with limited clearance for better cuts and fewer secondary operations. The extreme bevel consumables are available for both air and oxygen cutting at 130 and 200 amps.603-643-3441
www.hypertherm.com
PN: 528058
Chassis & Suspension Tech
Jan 7, 2021 11:30 PM
May 15, 2019 04:47 PM
1ATony
1A Autoparts
Jan 18, 2012 09:41 AM
