DIY How to clear coat repair
In this video I am going to not only show you how to repair peeling, chipped or worn out clear coat. I am going to show you how to do a spot repair and blend the new clear coat into the old clear coat. Some might call this a Hack but they will be disgruntled body shop workers
joking aside,
this is not a long lasting repair and your results will vary based on how bad the clear coat damage is on your car and how much discoloration has resulted on your base coat.
https://www.youtube.com/watch?v=lbSIjsUeWZQ
Here are links to products which were used in this video:
My Car Wash Soap: http://amzn.to/2dRT071
Microfiber Towel: http://amzn.to/2diBBAh
Gray Scotch Brite Pad: http://amzn.to/2eCW7kx
1" Masking Tape: http://amzn.to/2e2izBl
Blue Shop Towels: http://amzn.to/2ehKaxD
2K Clear Coat: http://amzn.to/2e2ki9N
Painters Respirator: http://amzn.to/2ddSdhH
1500 Grit Sand Paper: http://amzn.to/2dDMbmn
7" Polisher: http://amzn.to/2dV4Xen
Wool Pad: http://amzn.to/2dV6zoA
Medium Grit Rubbing Compound: http://amzn.to/2dV7Yvq
joking aside, this is not a long lasting repair and your results will vary based on how bad the clear coat damage is on your car and how much discoloration has resulted on your base coat.
