Gene Winfield How to Lead techniques
Gene Winfield How to Lead techniques on Tampa Racing
https://www.youtube.com/watch?v=87fuTnBS2bE
Legendary Gene Winfield stops by Eastwood to give a lesson in the lost art of leading, where heated lead is used much like body filler to smooth & fill panels.
LINK FOR ALL YOUR LEADING NEEDS:
http://www.eastwood.com/autobody/lead...
LINK TO BUY BODY SOLDERING KIT:
http://www.eastwood.com/ew-body-solde...
LINK TO BUY TINNING BUTTER: http://www.eastwood.com/ew-tinning-bu...
LINK TO BUY BULLSEYE PICKS:
http://www.eastwood.com/bullseye-pick...
Eastwood Body Solder kit Deluxe with DVD
Item #11167
Eastwood's Deluxe Body Solder Kit has more of what you need to fill with better adhesion, strength and durability than plastic fillers 30/70 lead-based body solder is slightly easier to work with than our lead-free solder, and provides better adhesion, strength and overall durability than plastic fillers. Includes a big 5 lbs. of solder for serious soldering pros.
Spreadable (plastic) range is 361-489 degreesF
Includes tools and accessories
"How-to" DVD included
In 1955 "Bondo" came out as the first plastic body filler and made fixing imperfections in metal much easier than before. Today fixing dents and smoothing imperfections in a body panel has been simplified to where it's almost as "easy" as mixing two bits of putty, applying it to the panel, and sanding it all smooth. Before those days the only option was the process of "leading". During this process you melt sticks made up of mostly lead and a small portion of tin onto the surface. With the invention and evolution of plastic body fillers the art of leading a body panel has been slowly dying out, but if you want to keep "traditional" or true to the era of the car you're building; leading is the only way.
Only a few guy from the golden age of kustomizing and hot rodding are still with us, and even less are still working on cars. One of the best is Gene Winfield and even today, well into his 80's he's still traveling the world kustomizing old cars and teaching classes about metal shaping, leading, and anything you want to know about custom cars. I was lucky enough to catch up with him at one of his recent metal working seminars to get the process he uses to apply lead to a panel.
Gene is a long time Eastwood customer and supporter. In fact he use Eastwood leading supplies and claims we have some of the best products to apply lead on the market!
Item #11167
Paint, Body, and Detailing
05-10-2017 08:48 AM
12-04-2015 12:26 PM
05-27-2014 11:00 PM
