sandy/texture finish.....why?
So the last couple of times I have sprayed primer with the most recent being tonight I end up with a dry/texture/sand paper finish. I have done my research and can't seem to find an answer.
I'm using a devilbiss gun and have tried a 1.5 and 1.8 tip. It requires 30psi at the gun which its getting. Iirc it sprayed better when I had just bought it.
Any ideas of what can cause it. I know paint age, psi and all that stuff can cause it but what is the most common you guys know of?
I going to start by taking the gun apart and clean it to make sure there isn't anything holding up the paint....
fender roller rental
shared_pm me for info
Temperature--its just drying to fast in this heat. Try a splash of retarder to slow things down.
Automotive Paint/Minor Body, Wheel Painting, and much more for Great Pricing!!!
Working with 15+ years of Professional experience,PM me for Price Estimates & Location.
Temp,like oldschool said,dirty gun like you said and material flow,open that gun up all the way.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
yeah ive messed around with all that stuff but nothing has worked at all so im hopeful theres something restricting the material flow. havent had time to take the gun apart yet, will try to do it in a little bit.
throw some reducer in that shit....its like 432 degrees out side. that should help.
Josh
Josh
Josh @ Hellfire Studios
Custom Paint, Collision, Bikes
<Severed Ties> FL
"Diamonds are forever!"
<Severed Ties> FL
Dont know what prime it is but cheaper primers are natorious for dry spray. Need to flow it out wit large tip and slower evap. rate.
So I ended up opening the gun and everything seemed ok. I'm done spraying primer and started spraying base a lil while ago. The base seemed fine. Oh and I'm using some nason products @ 90degrees I can't complain.lol
reducer aka thinner 4 1 1
Quote:
There is some added programer on it and it is suppost to run great the previous owner ran from the cops on it and got busted
apparently it doesnt run that good lol
