Other Makes Look in the Sub-forums, if you vehicle's make is not list you can post below. Please Post in Correct Forum
oil drain bolt leaky
Old Aug 27, 2008 | 07:43 PM
beebo10's Avatar
Mazing
Default oil drain bolt leaky
it doesn't fully tighten. what's the best way to fix this without replacing the oil pan?
Old Aug 28, 2008 | 04:55 PM
wmartinlsmith's Avatar
a crush gasket..
usually made of bronze, aluminum, or plastic.. have to use them on the volvo or it leaks like a siv..
Bill the locksmith
I have a volvo..
Old Aug 28, 2008 | 04:59 PM
94CIVIC MAN's Avatar
count to ...10
replace it or you will always have problems... wats going to happen the next time you want a oil change.. your going to have to take it out again if you seal it or whatever you do..
