Help!!
Old Jun 2, 2003 | 07:09 AM
Enthalpy's Avatar
TR Balla Donor Supreme
Originally posted by Sickly240
the only ones that matter are the ones after the throddle body, correct? If that's the case than I don't think there is any..
On a Mass air-flow car any leak between the air flow meter and the cylinders is a problem. but see my above post for your real problem.
Scott
Old Jun 2, 2003 | 08:07 AM
Sickly240's Avatar
the 13 code is no longer showing......the reson it was sowing was because my friend happened to disconnect the plug before i put the ecu in diagnosis mode 2, i think..... i just went down to my garage and checked again for vaccum leaks, nothing....I just dont understand, why it won't stay idling..........thanks...also when it actually turns over you have to open the throddle body up all the way for it to even start, and as soon as you let it go it's done for.... i'm getting really fend up with it so if anyone that knows how to diagnosis the problem, and would be will to come take a look at it, i'm sure i'll throw you some cash............
Old Jun 2, 2003 | 08:14 AM
Sickly240's Avatar
sounds damn good for the second it runs................
