LSD - S13 guide
Old Apr 2, 2003 | 02:28 PM
marksaccord95's Avatar
TR Registered Member #5
Default LSD - S13 guide
ok this is the only thing that confuses me. There is the JDM S13 LSD, S14 ABS VLSD, J30 LSD, etc etc.
Now which LSDs can you 'bolt' into the stock s13 pumpkin, and which requires the pumpkin, but still bolts to the factory axles?
http://www.floridaracing.org
Old Apr 2, 2003 | 03:43 PM
Enthalpy's Avatar
TR Balla Donor Supreme
dude...heres the deal. you use the pumpkin the diff comes in. you just change the back cover to your S13 cover. you dont need to swap the diffs out of the pumpkins. furthermore, if you get JUST a diff and want to put it in your pumpkin then you are either goign to have to buy LSD outputshafts ...and theres like 10 diffreent types...or have yours custom machined (talk to mattback). when buying a used VLSD for your car please specif to your parts suppler that you need the entire diff assembly with output flanges. adn that the output flanges need to be the 6 bolt variety.
An ABS S14 / J30 diff will work just fine in your car. the clearance is tight but it works fine. i have aone in my car with no problems and no custom mods to get it to fit.
Scott
Old Apr 2, 2003 | 05:36 PM
Matt Vassallo's Avatar
lifelong learner
not necessarily true
bring me any vlsd
and i will put it in your pumpkin and use your output shafts.
rest in peace tim.
Old Apr 2, 2003 | 06:18 PM
Enthalpy's Avatar
like i said ASS
"if you get JUST a diff and want to put it in your pumpkin then you are either goign to have to buy LSD outputshafts ...and theres like 10 diffreent types...or have yours custom machined (talk to mattback). "
Old Apr 2, 2003 | 07:22 PM
so all the 6 bolts are the same? IE: not a 6 bolt thats spaced differently then another
Old Apr 2, 2003 | 10:14 PM
lifelong learner
i dont believe there have ever been two breeds of six bolt, as far as the flagnes go.
six bolt stuffs = six bolt stuffs
star shaped = star shaped - 5 individual, not tripod style (six bolt)
rest in peace tim.
Old Apr 3, 2003 | 08:43 AM
so like a z32 6 bolt will bolt right into a 240, or do u need any custom brackets
Old Apr 3, 2003 | 08:55 AM
Enthalpy's Avatar
Z32 were all 5 bolt
Old Apr 3, 2003 | 09:22 AM
lifelong learner
exactly. z32's are all star shaped.
so are cefiros, q45s, and other certain beasts.
generally if they were 6+ cylinder powered, they were 5 bolt powered. however earlier z31s are 4 bolt. (and they are 4 HUGE bolts)
some skylines are 6 bolt however, depends .. its wierd.
stick to a six bolt and you'll be fine.
however you can get a 5 bolts, you just need to swap output shafts.
best bet is to post and ask if its a good diff. and we will tell you what will need to be done to make it work, since you obviously can't read any faq's yourself on it.
rest in peace tim.
Old Apr 3, 2003 | 10:54 AM
dan's Avatar
dan
Get the fuck off my lawn
http://www.cautioncreativity.com/briand/lsd.htm
