speed limiter on 240?
Old Mar 19, 2003 | 04:18 PM
ANOTHER_240sx..'s Avatar
unprofessional drifter?
Default speed limiter on 240?
Where do I go to get the chip to get rid of this damn speed limiter. I hate it. I was doing 115mph, then all of a sudden it kicks in and I can't go anywhere.
Old Mar 19, 2003 | 09:14 PM
dan's Avatar
dan
Get the fuck off my lawn
if you are knowledgeable with electronics you can make one yourself using resistors and such from radio shack. a very cheap method if you know what you are doing.
greddy sells a speed cut killer device that is like 3 wires and its around $100 i think. kinda expensive but its like a plug and play thing or maybe just splice in.
its not a mod worth doing unless you will be doing over 115mph often, which isnt legal except at the track. id spend money on other mods to get you those 115mph traps before wasting money on the SCK.
ps - enthalpy made his own i believe, perhaps he can give you a diagram.
Old Mar 19, 2003 | 11:12 PM
Charles's Avatar
Senior Member
A nearly stock 240 has no balls whatsoever at 115mph anyway not like it will really pickup any speed in a hurry at that point, not worth it
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old Mar 22, 2003 | 05:54 PM
Durdan's Avatar
No Ants Drift Member
i beg to differ. but then again mine makes insane power numbers. but my car pulls all the way to 135 with no problem.. after that it take all of florida to reach 150's
its an easy mod. there are two ways to do it. above the ECU is a white plug that leads to your gauge cluster. theres a yellow wire with a green stripe. cut it. your speedo will still work and your ecu wont get a signal. after you do this yuou have to disconnect the 4th and 5th gear sensors on your tranny.
the othe rway i did was disconnecte fthe sensors and ran a toggle switch inline with my vehicle speed sensor. when i hit the swtich. it opens the signal and my speedo goes to 0. and the cars pulls.
RIP Tim. i miss you, buddy
Old Mar 22, 2003 | 07:27 PM
Charles's Avatar
Senior Member
92' Nissan 240sx
08' Tundra
