Oh God, I killed it, help me!!!
Alright i was doin around 100mph, around 6 grand in 3rd i believe down the interstate the other day when i heard some strange noises the tach started to go down, i lost power, then the engine died. when i tried to bring it back up it would crank but would not start. i got home, checked the timing chain because i thought thats what it was, i was wrong, the chain is fine. i also checked the fuel filter/pressure, its fine, i got sprayed. i pulled ecu codes, i got 11 and 34 which are camshaft position sensor and knock sensor according to 240sx.org. im at a total loss and i know there are people here with alot more 240sx experience than me, so if someone could tell me what they think might be wrong, i would greatly appreciate it
-nate
-nate
-Nate-
[xbox360]DETrimentS14[/xbox360]
-Nate-
what comes with the motor? uncut harness? ecu? stock ic? power steering pump? ac pump? alternator? ignitor chip? i assume a 5 spd tranny, what clutch/flywheel? shifter? anything else?
-Nate-
-Nate-
