setting vg30 timing
Old Feb 24, 2003 | 09:50 AM
foesicks's Avatar
Default setting vg30 timing
Found out the car had no ignitor , someone swiped it. We put in a ignitor and the cars fires a little but dosent start up, also gets a backfire just when it dies. Sounds like the timing off, also is the ignitor suposed to get hot enough to burn the hell out of your hand. Thanks for any help,
SOHC 1.6 VTEC
----CRX DX-----
Old Feb 24, 2003 | 11:55 AM
BumpinPSI's Avatar
Eye Heart Nissan
Every ignitor I've ever worked with has had to be grounded to something. There should be no reason for you to touch the ignitor. Get some dielectric grease, find out where the stock location is, and mount it. This car had the GReddy PRofecB box under the hood - are you sure the vacuum sources it was using are plugged or re-routed to their stock location? Sounds a lot like what would happen if you had a bad vacuum leak.
Tampa Bay Lightning - 2004 Stanley Cup Champions
