clutch master cylinder question ?
Old Nov 15, 2013 | 11:18 AM
obituary's Avatar
TR OG
Default clutch master cylinder question ?
have a brand new OEM clutch slave cyl ,and a slightly older autozone master ..
everything is bleed (no pamper)
.but i am getting clutch creep "car wants to creep forward" and is a bear to get into gear.
my thoughts are that the autozone is craptastic and not OEM,and that i am getting a fluid bypass internally in the master ,due to the new slave is giving the master alot more resistance .
is this a possibility? should i buy a OEM $100 master?
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
Old Nov 15, 2013 | 01:27 PM
Empire's Avatar
buildin' it
yeah, autozone parts have been known to be bad off the shelf, and not last real long.
is it possible to get it up in the air enough so you can watch the slave and see if it is a matter of it not moving as far as it should, or if it is a matter of it creeping back once it hits full engagement.
Old Nov 15, 2013 | 03:03 PM
rhart's Avatar
Because race car…
If you messed with you adjustment on you clutch pedal linkage check there first. It might save you a buck or two if you can adjust the "creep".
Cool that you removed the "pamper" box. Those things stink...lol.
If it has tires or boobs it's going to cost you money...
Old Nov 15, 2013 | 03:07 PM
obituary's Avatar
TR OG
it does move the fork...just doesn't seen like enough.
ha yeah (damper) box you know what i meant tho.
and have adjusted it. still sucks.
1972 nova ss
89 240 sr20det
Old Nov 15, 2013 | 05:43 PM
rhart's Avatar
Because race car…
Where did you get your OEM SR slave from? You are SR powered right?
Old Nov 15, 2013 | 10:30 PM
KRUKED's Avatar
.....taste the rainbow
+2 for adjusting the push rod mor...linking the master to the pedal.
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Nov 16, 2013 | 05:36 PM
omgosh's Avatar
I dont know about Nissans, but on my DSM I know the advance/vatozone parts could come with different length rods on the slave cyl. Might check that compared to the OEM to make sure it is the same length.
When you adjust the clutch, you want to make the rod longer at the pedal (thread it out as if you were loosening a bolt) so that it presses the master more.
Otherwise Id say you need to bleed it better. What method are you using to bleed?
Old Nov 16, 2013 | 05:37 PM
Jr_SS's Avatar
S one 4
For some reason it seems like the AutoZone/off brand pieces are junk on Nissans. Anyone running OEM parts have zero or less issues than buying the cheaper counter part.
Old Nov 16, 2013 | 05:42 PM
obituary's Avatar
TR OG
yes SR motor.
Nabco ,new, made in Japan.
1972 nova ss
89 240 sr20det
Old Nov 16, 2013 | 05:43 PM
obituary's Avatar
TR OG
going to swap out to a new master OEM made in Japan 5/8 ,next week sometime.
1972 nova ss
89 240 sr20det
ninetysixEK
For Sale/WTB Honda & Acura
Oct 8, 2012 12:47 PM
HaTcH_MAn92
Sep 2, 2011 09:56 PM
Super Coupe
For Sale/WTB Nissan
Nov 5, 2009 02:48 PM
sam21
7
Oct 5, 2009 03:29 PM
DCLove05
10
Dec 31, 2008 01:45 PM
