s13 tach is a little jumpy
.....taste the rainbow
on
Welp...
The tach works fine at all times, it's just jumpy. Whenever I'm driving, cruising at a steady RPM, the tach will jump from -5 to +5 RPMs. When I hit bumps in the road the jump is more.
I did a little digging around, nothing spectacular popped up. Hope someone has some insight because I know other S-chassis owners have had this problem.
Thank yee.
Thank yee.
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
the only time I had jumpy gauges, the cluster started crapping out shortly afterwards.
I'm sure it is something that can be fixed, but I honestly don't know how. Maybe if it was obvious after you pull it all apart, you could solder whatever it needed, but If it was me, I'd just deal with it til it went out and get a new one in there.
on
Half of my crap around the column is already pulled out for whatever reason. Sometime this week when the weather isn't crappy, I'll delve into the cluster. I have a couple of tachs so I'll swap 'em around and see what happens.
Na306StAnG
12-23-2010 04:39 PM
options2rx7
12-04-2008 04:43 PM
