car jerking hard
Old May 27, 2012 | 07:48 AM
s13jzgte's Avatar
Default car jerking hard
Whats up guys last night my car started to jerk and bogg down when going into boost. It only does it in 1st get if i shift all other gears i can boost fine at full throttle any suggestions?
Old May 27, 2012 | 08:29 AM
s13jzgte's Avatar
Boost gauge reading -20 at idle and going into boost peaks at 7psi there are no leaks what so ever and i have a hks ssq atmos bov. It only happens in 1st gear as i said. Checked spark plugs there good coils look good no cracks but gotta put a ohm tester to it. I i cant figure out what it could be?
Old May 29, 2012 | 05:23 AM
4wheeldriftS13's Avatar
February - Ride of the Month
you'll have to be specific with jerk and bog part...
jerk is suspension or worn bushings. Bog is engine related.
More info is needed for diagonostics over the internet.
RIP Tim Aldrich
Old May 29, 2012 | 05:25 AM
although when I got into it this weekend, my car would break up terribly and as soon as it saw any sort of load or weight shift to left or right - it was the fuel pump sock, it had come off.
Not saying its your issue, but its possible
RIP Tim Aldrich
Old May 29, 2012 | 03:13 PM
s13jzgte's Avatar
Well if i do try to gas it hard into a turn it will kinda buck back and fourth power in my car will reset. I unplugged my tps sensor drivecitcaround the block. Plugged it back it and it hasnt done it since. I have a stock sr with a walbro 255. Im thinking it was my tps cuz it hasnt done it since i plugged it back in but it still kinda does it still gasing into corners
Old May 29, 2012 | 03:15 PM
s13jzgte's Avatar
I have a z32 fuel filter...walbro 255..everything else is stock. But as i said it only does it when taking off in first or gasing it into corners in first or second
Old May 29, 2012 | 04:56 PM
sullivanracing06's Avatar
dose it do this with a full tank of gas? or only when your low on gas?
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
jstone8952
Jun 23, 2009 09:33 AM
aznfish
May 22, 2009 04:30 PM
snoopy10
Feb 15, 2008 02:16 PM
MadisFastDSM
Jan 5, 2005 06:32 PM
