I need more front travel!
Old Mar 8, 2012 | 07:44 AM
mewantkouki's Avatar
no
I spy t3 camber plates.
Old Mar 8, 2012 | 07:58 AM
rhart's Avatar
Because race car…
How much $$ do you have tied up in that set up?
If it has tires or boobs it's going to cost you money...
Old Mar 8, 2012 | 08:05 AM
BABILLARACING's Avatar
Originally Posted by omgosh
^Cant tell if thats sarcasm? lol
Seriously though, s chassis front suspension blows ass.
8611 setups/coilover porn:
nice set up you got there mister, if you don't mind me asking where and how much you paid for the cartridge housings? I am planning to do something like that
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Mar 8, 2012 | 10:51 AM
omgosh's Avatar
ah I just pulled those pics off Nissanroadracing. The first two are 8611 double adjustables in user "veilside180sx" custom strut housings. They go for like $300. The chrome one is a koni yellow setup like mine. I picked my Konis up for $100 with ground control sleeves.
Old Mar 8, 2012 | 11:28 AM
damn $100 that is a hell of a deal. I guess i gonna fabricate some housings. Thanks again....Omar
My shit still slow
Old Mar 8, 2012 | 12:10 PM
omgosh's Avatar
If you can weld they are easy to make. Or cheaper than $300 to get made anyway lol. Just get the diameter of the strut cartridge, and use a stock strut housing for reference...move the strut tube down on the knuckle mounts to lower the car without sacrificing travel..
I have AGXs in the back right now...I want to switch to either a 3000gt or Evo8 Bilstein rear and convert to 2.5 inch.
As far as my front setup, I need some camber plates, roll center correction LCAs, and maybe a bigger sway bar and then I think Ill be able to decide if the Konis are good enough...but Id still kinda like to try out a Bilstein 46mm setup up front too.
Old Mar 8, 2012 | 12:37 PM
  #17 (permalink)
I have right now kyb adjustables with sportline springs in the four corners , I was gonna rebuild my jig magics but i am unsure if i want to go that route, My car is gonna be set up for street and drag racing . anyway if you decide to part ways with the front set up lmk....Thanks....Omar
i am already study my options also Tommy is helping me out
My shit still slow
Old Mar 8, 2012 | 01:42 PM
  #18 (permalink)
Empire's Avatar
buildin' it
good job figuring it out omgosh.
props to you
i'm actually going down that same road trying to determine how I want to set up the suspension in my 300zx. Since this particular build is a daily driver, comfort is pretty high up on the priority list.
We actually drew up something very similar to your set up you posted as an option.
Old Mar 8, 2012 | 04:53 PM
  #19 (permalink)
omgosh's Avatar
Let me just say Koni yellows with 8k springs ride better than AGXs and Sportlines. At the same time they manage to handle better than the JIC, Godspeed, and KEI Office coils Ive tried ( I know, not exactly quality, cutting edge shit, but still ) With the KEIs I actually had to slow down for PAINTED crosswalks...shit was retardedly jaring.
Omar...do you think you would be able to grind the welds off the strut tube bracket and just slide it up the tube? It looks to me that you might but I dont work with metal that much. That wouldnt help much for an 8611 setup, seeing as the cartridge has a wider OD then the ID of the factory tube...but maybe for another insert? What do you and Tommy have in mind for that blue (Tokico?) tube?
Old Mar 8, 2012 | 05:32 PM
  #20 (permalink)
right now Tommy is trying to find parts to rebuild the jic's but the front cartridges have some surface rust and even if we clean them they gonna mess up the seals .option two is use bilsteins 34-050224 in the front to used it with the jic housings. option three is use the tokico front spare housings i got with koni 8611,8610 or 8641-1364 sports , in the rear i going to use koni 8611 . I guess i got to buy ground control coilovers to make it work ,also i got to fab some rear housings . these things add up pretty quick lol . The car is gonna be daily drive and drag racing . I don't want to be too low just set up the right way for drag and drive around.
My shit still slow
