S13 sr20 milky oil
Old Jun 16, 2011 | 08:58 PM
s13 madison's Avatar
SLAMMED!!!!!!!!!!
Default S13 sr20 milky oil
Now I know what everyones thinking, bad head gasket, But I dont think so.
I just recently purchased an s13 sr longblock from Jdm of Miami who compression tested the motor and everything and Im pretty sure that they would have caught the bad gasket. I've checked the oil and coolant lines from the turbo and there correct and if it matters I bypassed my heater core with a u shaped tube. Tonight we were setting electrical timing and we started and shut the car off a lot, plus my ignition is screwey so sometimes the fuel pump turns on and the starter doesn't go. My question is, if there was an excess amount of fuel in the cylinder, would it be possible
For it to somehow pass through the rings and mix with the oil? And if not, where else should I start looking? I've been researching for about 45 minutes and can only find limited information
93 Nissan 240sx - sr'd slammed hella flush money pit
98 BMW m3 sedan - alpine white, stage 2, bilstiens, dinan brakes, soon to be flush daily
Down and Out
Originally Posted by BAMF
Thats like saying if I get a heart transplant from a black dude I get 20 acres and a mule. Hogwash.
Old Jun 16, 2011 | 09:00 PM
SLAMMED!!!!!!!!!!
I haven't got a chance to smell the oil yet, and when I do I'll post whether it's water or fuel
Down and Out
Old Jun 17, 2011 | 03:47 AM
Davetheslave's Avatar
Try changing the Oil. Then start it for like 10-15 seconds. Then do that again. Did you pressure wash the motor or did it get rained on?. That's all I can think of
Formerly Earlkel OG join date 8-14-2003
Old Jun 17, 2011 | 11:04 PM
Empire's Avatar
buildin' it
it is a blown head gasket.
period
that's really the only way that can happen. with the exception of things like getting the lines on the turbo backwards which is difficult considering how different they (should) be.
you don't have to drop compression to have a blown gasket. just because the oil and water is mixing doesn't mean the compression ring is blown.
As for your fuel mixing with the coolant/oil, the only way that happens is A) terrible piston rings, and running rich for a considerably long time (like several months) and/or B) blown head gasket where the coolant is leaking into the cylinder, causing a terrible combustion, running rich, and compressing the unburnt fuel out and into the coolant/oil.
Don't believe me, do like someone else suggested and flush it out and replace the oil, run it for a bit, 10 bucks says it gets milky within the day.
Just FYI, water will rust bearings. even water mixed with oil. not to mention how much it doesn't actually lubricate anything.
and that oil that it is in your coolant passageways will clog things up, and cause all kinds of cooling problems as it will coat the sides of the passageways preventing the heat to transfer from the metal to the coolant properly.
So my advice it to tear the whole thing down and get it actually cleaned out. Everything from the head, to the hoses, to the radiator.
good luck.
Old Jun 18, 2011 | 06:56 PM
omgosh's Avatar
Also you could test the coolant for hydrocarbons...
Old Jun 19, 2011 | 07:19 AM
supreams14's Avatar
I think importers do compression test's on the motor when its cold.
Leak-down test time!
I think you can rent it from an auto parts store. It goes on your rad cap, then you pressurize the coolant system( do it on a warmed up motor).
My daughters mother had milky oil in her 96 maxima and I was pissed. Did a little research and found out the FWD vg30 has a internal water pump and when the seals go bad the oil and water mixes. This is not the case on an sr.
Old Jun 19, 2011 | 06:58 PM
SLAMMED!!!!!!!!!!
I really don't think it's the head gasket, there's no milky shit in the coolant or under the caps, is there any crossed lines or other crazy possibilities, I ran the combustion gases test and the liquid stayed blue, given it was my first attempt I'm gonna try again tommarrow
Down and Out
Old Jun 19, 2011 | 08:53 PM
sean1's Avatar
i has double turbo
thats a cooling system pressure tester, a leakdown test is when you compress the combustion chamber through the spark plug hole, to find leaks like headgasket, rings, valves, or a crack
my honda sounds like a lawnmower, because it is one.
Old Jun 22, 2011 | 09:39 PM
SLAMMED!!!!!!!!!!
Figured it out, the motor came over with water in it. Flushed it out 3 times and it was good
Down and Out
-Mike
For Sale/WTB Nissan
Mar 5, 2011 06:11 AM
Superkaioken
For Sale/WTB Nissan
May 28, 2006 08:59 AM
compleks delsol
Nissan/Infiniti Tech
11
Mar 26, 2004 02:01 PM
