have a question about pistons???? Please help
Old Oct 15, 2002 | 05:49 PM
dgsilverbullet's Avatar
Watch out he's Spraying
Default have a question about pistons???? Please help
Can low comprsion pistons stock or aftermarket from a 300z will fit in a 3.0v6 maxima motor????????
Old Oct 15, 2002 | 11:08 PM
Matt Vassallo's Avatar
lifelong learner
if the bore is the same and the rods are relatively simlar then yes.
rest in peace tim.
Old Oct 17, 2002 | 10:51 AM
Thats my question?? There the same motor 3.0v6 so can i take the pistons out of a 300 and put them in a maxima and run boost??? The bore should be the same and i would use 300 rods too right??
Old Oct 17, 2002 | 12:06 PM
Chismoe's Avatar
Craving Boost
Actually I think the bore and stroke are different from the VG series to the VQ.
I'm assuming your talking about using the pistons from the Twin Turbo 300zx motor and not the N/A motor.
Old Oct 17, 2002 | 12:07 PM
Chismoe's Avatar
Craving Boost
Chismoe's Avatar
Craving Boost
Old Oct 17, 2002 | 12:32 PM
Dr Evil's Avatar
Darren - The bore x stroke on the VQ ( maxima ) is 3.66 x 2.89 inches and the bore x stroke on the VG ( 300zx ) is 3.4 x 3.3 inches. So they would not fit, and you could defiently not use the same rods. Although both are 3.0-liter 24-valve DOHC 60-degree v6's, the bore and stroke are both off.
Holy triple post chismoe
Old Oct 17, 2002 | 04:01 PM
dan's Avatar
dan
Get the fuck off my lawn
JE, Arias, and other companies will custom bore pistons to your requested measurements. it will cost money, but unless a company already makes low compression vq series pistons, this is the only way to go. (other than being ghetto and stacking head gaskets haha)
Old Oct 17, 2002 | 08:55 PM
Thank you vary much for the knoledge i will now tell my friend what he needs to do .. Thanks Ive looked around for pistons and rods they are very hard to find any help on that would be greatful..
Old Oct 18, 2002 | 08:04 PM
lifelong learner
all you have to do is pull a piston send it to je say listen make these forged and low comrpession and they will comply
rest in peace tim.
