coilovers stuck!!!!!
Old Dec 27, 2010 | 03:30 PM
c89s13's Avatar
Default coilovers stuck!!!!!
So i was planning on adjusting my ride height and the bottom housing wouldnt budge from the shock on my rear coils. I sprayed them with pb blaster and wd-40. Got a pipe wrench, tighten the perch locks, and tapped the crap out of it while gripping both perch locks with the pipe wrench and still did not budge. Tomorrow i will heat them up with a hair dryer like my friend told me(jc.lol).
Anyone else know a trick for this?
fender roller rental
shared_pm me for info
Old Dec 28, 2010 | 04:55 AM
Empire's Avatar
buildin' it
what kind of coil overs?
they should have a tool specific to them.
I have never had any problems when using that actual tool. Might have had to use a little piece of pipe for more leverage, but it didn't bust my nuts or anything.
Old Dec 29, 2010 | 09:31 PM
Z350man's Avatar
Blah Blah Blah
use the spanner wrenchES as in both spanner wrenches and tap them lose.
Old Dec 30, 2010 | 11:21 AM
c89s13's Avatar
Thanks guys for the ideas. I managed to get one out with slightly scratching the lower mount/housing. Now the other was a different story. I basically had to cut the housing enough to were i was able to pry it open. Now i need to order a new lower mount and perch locks.
Old Jan 2, 2011 | 05:14 PM
SS#1156's Avatar
Condom tester
get some Hilco lubricant. This stuff is AMAZING!!!!!!! I used this on exhaust bolts that were rusted sooo bad. I sprayed them for a few days and when it was time to remove the bolts they came right out. I swear by this stuff. Good luck man.
1995 Nissan 240SX SE (Looking to do some mods & need help)
1993 Saleen #20 of 56 Hatchbacks
SCOA FL State Rep
Old Jan 12, 2011 | 07:33 PM
Jared Noriega's Avatar
I put a solid pipe through the bottom of the coil where it would bolt on and torqued on it while a buddy held the top with the spanner.
I love my honda, when it pressure washes my nissan.
Build threads
S13 coupe
https://www.tamparacing.com/forums/n...ht-purple.html
Kouki
https://www.tamparacing.com/forums/nissan-builds-projects/688726-kouki-project.html
