Will a 97 j30 diff bolt right into s13???
Old Dec 22, 2010 | 07:46 PM
Bullitt_S13's Avatar
(O=O/--RPS13--\O=O)
Default Will a 97 j30 diff bolt right into s13???
I know 94 and earlier need modification to work, and 95+ have the same 6 bolt flange and bolt right in, but everywhere I've read say they aren't sure if the 97 bolts in without modification.
Old Dec 23, 2010 | 03:09 AM
rhart's Avatar
Because race car…
I've been researching this option for a dif too. Those '94 and earlier J30 difs have 5 bolt output shafts much like the 180sx dif I ended up grabbing.
But I do believe you will find that their installation into a s13 chassis is the same for the later J30 difs. That would mean its much like bolting an s14 dif into an s13. Both the J30 and s14 have a 2 rubber mounts in the front "ears" of the dif, where the s13 bolts directly, no rubber isolators. You will need to use your s13 rear cover because it 4 bolt, not 2 and front mounting bolts because they are longer...essentially the exact same thing as if you were using a '94 and earlier dif from a J30.
Here is some good info too: http://www.ka24development.com/vlsd.html
Consider yourself lucky not to have to have to source out different axles or output shafts. Though NAPA does have the 5 bolt axles for the cheap, as i was shown yesterday by NeedCAfors13.
Hope this helps and that others chime in to confirm.
-Royce
If it has tires or boobs it's going to cost you money...
Old Dec 23, 2010 | 10:40 AM
Empire's Avatar
buildin' it
^ thats it, to the extent of my knowledge.
Old Dec 23, 2010 | 12:53 PM
-Mike's Avatar
Formerly IThaJokaI
Napa does not keep the 5 bolt axles in stock, takes 4-6 weeks to get one.
I just went through this for my r32 diff.
All you need is the j30 front diff bolts, and swap the s13 cover on. Done.
Old Dec 24, 2010 | 03:37 AM
rhart's Avatar
Because race car…
Really? Who knew they just wouldn't have them on the shelf. Seems like the more l check things out for cars like ours they are special order. And since I cant imagine the J30 being as popular as the 240, axles will be just another item to add to the list of something we could use but need to wait for.
The OP is lucky with his dif is 6-bolt and will just drop right in.
-Royce
Old Dec 24, 2010 | 05:55 AM
mewantkouki's Avatar
no
Everywhere carries off the shelf parts for a 15-20 year old car.. Go figure?
Old Dec 24, 2010 | 08:56 AM
rhart's Avatar
Because race car…
Dang it I need to figure out a way to get sarcasm to bite a little more in these forums...lol
Old Dec 24, 2010 | 09:47 AM
-Mike's Avatar
Formerly IThaJokaI
Advance carries s13 axles in stock, just saying.
Old Dec 24, 2010 | 11:46 AM
rhart's Avatar
Because race car…
...and don't even list the j30 5-bolt any more...
Old Dec 24, 2010 | 07:23 PM
wheelman167's Avatar
drifter
it will just inspect the bushings on the front cause youll need longer bolts, you could just buy solid inserts instead, im using j30 internals with a open diff ring gear in a open diff housing.
