Need Wiring done on my s13 sr20
Old Nov 23, 2010 | 09:52 AM
AUDIcabrio09's Avatar
Default Need Wiring done on my s13 sr20
i am not getting power to the injectors..i have tryed a different ecu and changed the egi relay ad egi pump ralay... i think there could be a problem throughout the harness but i am not sure at the moment. I would like to have someone who knows more about the s13 chassis more than i do and find this problem!!! i am located in kissimmee..i am willing to work something out..call or text 3214023091 kerry
Old Nov 23, 2010 | 11:55 AM
DSMSpoolin's Avatar
Judge Fudge
is your injector ground hooked up?
Many cars: Sold
1990 black top SR 240sx Coupe: Current
They use shitty skylines like this as taxi's in japan
Old Nov 23, 2010 | 01:03 PM
I made sure the pin didn't come out of the ecu. It was good, along with all the other pins. Everything is plugged-in under the hood. What injector ground are you talking about.
Old Nov 23, 2010 | 02:11 PM
Empire's Avatar
buildin' it
"ENG CONT" fuse make sure that one is good... without it, the injectors won't get power
Old Nov 24, 2010 | 07:50 AM
Fuses are good
Old Nov 24, 2010 | 07:51 AM
Keep in mind I AM getting power to the relays! Hmm
Old Nov 24, 2010 | 08:00 AM
Empire's Avatar
buildin' it
Originally Posted by AUDIcabrio09
Fuses are good
you think they are, or you pulled it out and checked to know for sure it is?
beyond that, the injectors share a common ground, so maybe you missed the ground.
Old Nov 24, 2010 | 08:16 AM
Empire's Avatar
buildin' it
and make sure your injectors themselves are just shot. hit them with power straight from the battery and they should spray (assuming there is pressure in the lines)
Old Nov 24, 2010 | 08:24 AM
i pulled them all and everything checked out fine.. i will double check them in a min just to be sure..i have everything grounded i am sure..where should i be looking for the actual injector ground????
Old Nov 24, 2010 | 09:40 AM
ok so i lied....i AM getting power to the injectors, but ONLY when i crank the car over... I thought there was always suppose to be 12v when the key was in the on position?? correct me if im wrong...help me start this bitch today!!!
