s14 sr20 redtop, NEED HELP!!!!!!!!!!!
i just picked up a sr20 redtop s14, runs great but everytime i get on it, and the boost maxes out it dies, i was told its overboosting. so im tryin to learn. if you can help please call me 4239231612, any help would be help
~~~~~~~~TEAMXTREME MOTORSPORTS~~~~~~~~
1998 Kawasaki ZX6E
1987 Mustang GT Vert- 373 gears, 40s flowmasters with Hpipe, CURRENT
1996 Mustang GT- 373 gears, 50s flowmaster with h pipe, hids-Traded
S14 with Sr20det - DD and DRiFter-SOLD
91 S13 coupe- Sold
~~~~~~~~~~~LOVE TO SLIDE~~~~~~~~~~
1998 Kawasaki ZX6E
91 S13 coupe- Sold
Connect your wastegate.
it is everything looks fine
1998 Kawasaki ZX6E
91 S13 coupe- Sold
1998 Kawasaki ZX6E
91 S13 coupe- Sold
Check the hose for cracks and holes. Your wastegate flapper might be stuck shut as well.
yea that makes sense so i am checking it. thanks again , if it is bad do you know what type of wg i should look for
1998 Kawasaki ZX6E
91 S13 coupe- Sold
1998 Kawasaki ZX6E
91 S13 coupe- Sold
depends if your running stock bottom mount turbo.. if you are just get a hks adjustable wastegate im sure if you post wtb in the forsale area someone probably has one laying around.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
been checking it out. turns out its not the gate, its the setting on the boost con. they are way off, but i dotn know whats the best setting on it, its a greddy profec b spec 2,
1998 Kawasaki ZX6E
91 S13 coupe- Sold
1998 Kawasaki ZX6E
91 S13 coupe- Sold
Turn the duty cycle down to 10% and put the gain to 0%
ok so i did turn it down to what you said. but no change. anytime i give it gas and the boost gets up there it kills the motor and i have to stop and restart...i dont get it. and i noticed that even tho i turned it down i still am getting like 15 psi i dont get it. if you can help or send me to a good shop let em know im sure i need it tuned as well.
1998 Kawasaki ZX6E
91 S13 coupe- Sold
1998 Kawasaki ZX6E
91 S13 coupe- Sold
so i took the spark plugs out, i started with the front of the motor. and starting with 2nd on e back it had abit of oil, then by the last one it had alot of oil in the cyl. so can someone shine some light, do i need a top rebuild....its a sr20det redtop
1998 Kawasaki ZX6E
91 S13 coupe- Sold
1998 Kawasaki ZX6E
91 S13 coupe- Sold
