Car overheats, before i replace the headgasket, please help
stock sohc ka24
Ive replace the thermostat, radiator, rad. cap, fan clutch, and water pump.
Cant drive the car for more than 15-20 minutes before it pins out into the "H", and the resivior is bubbling over.
Everyone I know says its a blown head gasket, but the car starts up and runs fine, what gives?
Do a compression test? Bleed out all the bubbles? Check temp sensors? Milky oil or oily coolant?
The coolant is fine, its not milky or oily. I work for a fast lube, and I flushed the coolant myself, there are no air pockets.
Its doesnt blow any smoke out of the exhaust.
If the fan and thermostat are mechanical, the temp sensor has nothing to do but register how hot everything is.
