sr20 Surging problems help
First here is my setup. Sr20det(redtop),N60 MAF, q45 ignitor, and 550cc injectors, safc2(but not hooked up). Now when i start the car it has a problem staying idle so I have to give it some throttle. After that it starts surging. I've checked my wiring to the maf and that is good. I check for voltage at the iac and i have 12v at one wire. I also swapped the iac out with another and it did the same thing. I really dont know what else to try or do. If someone has experience with sr's please help. I'm a noob with these engines. thanx
if you have a diff maf other than the stock one and dont either have tuned ecu for it or a safc hooked up its going to run like shit. either hook up the stock maf or wire in the safc and adjust for it
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
