Passenger door won't open
Old Jun 15, 2010 | 02:43 PM
170k240's Avatar
Will Drift For Tires
its nearly impossible to get the door panel off without taking the dash out.
Originally Posted by Empire
could have saved you from tearing up your door panel....
how is that?
Nissan North America - Canton
Old Jun 16, 2010 | 04:11 PM
170k240's Avatar
still cant get the door open. any more ideas/help?
Old Jun 16, 2010 | 09:07 PM
mewantkouki's Avatar
no
Originally Posted by 170k240
how is that?
Old Jun 17, 2010 | 11:32 AM
170k240's Avatar
Originally Posted by mewantkouki
mind explaining yourself?
Old Jun 17, 2010 | 11:36 AM
Empire's Avatar
buildin' it
Reread your thread dude. You've been given the answer and the explaination as to why.
Old Jun 17, 2010 | 12:46 PM
170k240's Avatar
reread what i've said. you could use every slim jim on earth on this door mechanism and it will not open the door. every rod is still connected. i can push the actuators on the opening mechanism directly with my fingers and it still will not open the door.
NOW would you like to explain to me how i could have gotten the door open without taking out the door panel?
Old Jun 19, 2010 | 10:59 AM
  #17 (permalink)
Empire's Avatar
buildin' it
If everything is connected and moving the way it should, then I don't understand why you can't get the door open. Unless something is broken, and not moving the correct way, it will open the latch. Since you have the panel off, just unbolt the whole assembly. Get the door off and either figure out what was broken, or replace the whole door itself with a good one.
You have ruled out a punk ass buddy gluing the door shut, right?
Old Jun 22, 2010 | 09:50 AM
  #18 (permalink)
rhart's Avatar
Because race car…
Dude...someone pulled the dreaded "Dukes Of Hazard" mod to one side of your ride while the car was parked over night...take it to Cooter's garage...he'll hook up you! Yeee Haww!!
Seriously now...this really suck. Aside from cutting...you may be SOL. Sorry for your luck.
If it has tires or boobs it's going to cost you money...
Old Jun 22, 2010 | 10:56 AM
  #19 (permalink)
170k240's Avatar
i ended up drilling a hole through a rivet in the locking mechanism that the lock swung on. got it open, pulled the faulty lock out and replaced it with another i had.
Old Jun 22, 2010 | 11:05 AM
  #20 (permalink)
rhart's Avatar
Because race car…
Glad you solved this problem. This will be a good fix to know so if this happens to any us soon to be antique owners!!
