rb25det oil pressure ??'s
Old Jun 11, 2010 | 07:34 PM
AWD4g63's Avatar
Default rb25det oil pressure ??'s
i have a few questions from rb owners. my oil pressure bounces between 80-110 when cold started and settles around 20-25 at operating temperature. im running valvoline 20-50 oil and am oem oil filter. is this a good oil pressure for this engine?
Skyvia - The Best of Both Worlds
Old Jun 12, 2010 | 07:35 AM
mewantkouki's Avatar
no
Oil pressure will always be higher when the engine is cold. It seems alright to me.
Old Jun 12, 2010 | 03:43 PM
sullivanracing06's Avatar
yes that is fine, is this a r32 or r33 motor?
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Jun 12, 2010 | 05:37 PM
AWD4g63's Avatar
Its an r33 series 1 rb25det. The reason I was wondering is because there is an oily substance in my coolant...and I've only put clean 50/50 antifreeze and water in it. But my oil is fine and not all milkshaky. So idk if I'm losing oil pressure or something somewhere into my cooling system.
Old Jun 12, 2010 | 08:19 PM
your motor have a ignitor or no ignitor? if none then its a s2 has the ignitor built in the ecu
flush the system n see if it still there
Sullivan Racing LLC
352-665-2496-Tom
Old Jun 13, 2010 | 10:13 AM
AWD4g63's Avatar
its an s1. it has the igniter chip at the back of the engine ontop of the valve cover.
and ill flush it out and see if that clears it up. if not then im thinkin the headgasket didnt seat right when i put the head on it a couple months ago.
Old Jun 13, 2010 | 06:40 PM
did you use a oem or a aftermarket? cometic, greddy, apexi? arp or stock head bolts
Sullivan Racing LLC
352-665-2496-Tom
Old Jun 13, 2010 | 07:01 PM
AWD4g63's Avatar
Its a tomei mls headgasket and it has arp head studs
Old Jun 13, 2010 | 07:28 PM
you use copper spray on it?
Sullivan Racing LLC
352-665-2496-Tom
Old Jun 13, 2010 | 07:29 PM
shit flush it and see if that fixes it before we start talking a h/g
Sullivan Racing LLC
352-665-2496-Tom
