clutch issue
Old Apr 27, 2010 | 01:42 PM
Finkey's Avatar
boost > displacement
Default clutch issue
For the past 2 months or so my clutch hasn't "sprung" back up after I push it down, which makes driving a pain. I've already bled the clutch so that isn't the issue (same problem before and after) Anyone have an idea what's wrong?
>> YouTube - clutch_4-27-10.wmv (sorry for the beeping)
it's an act 6 puck unsprung (from what I was told when I bought the car) if that helps
Old Apr 27, 2010 | 02:34 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
well a brand new master is only like $45 and a brand new slave cylinder is $30 new replace both and it should fix it.
Drifting:
most fun you can have
with your pants on.
Old Apr 27, 2010 | 02:42 PM
mewantkouki's Avatar
no
Before you swap out the master and slave cylinder check to make sure your clutch pedal is bolted to the firewall properly. Contrary to popular belief there are three points where the pedal mounts to the car rather than two. I had a similar problem with a non returning pedal and low engagement in my car (originally auto) when I switched from a stock clutch to my stg. 4 competition clutch.
This is the bolt I'm talking about.
Old Apr 27, 2010 | 02:55 PM
Finkey's Avatar
there definitely isn't a bolt there, but the position of my clutch assembly seems awkward, like its not positioned correctly...
Old Apr 27, 2010 | 03:03 PM
no
Yeah, the missing bolt combined with a heavy pressure plate = hanging pedal. The downward motion of the pedal actually causes a slight bending of the firewall's sheet metal a without that bolt holding up the pedal properly. I'd try installing the pedal correctly first and then re-bleeding the system. If that doesn't fix the problem I'd look into the hydraulic system. I'm assuming your car used to be auto and someone 5 speed swapped it.
Old Apr 27, 2010 | 03:05 PM
Finkey's Avatar
Cool, thanks for the help
yeah it was swapped to a 5 speed before I got it
Old Apr 27, 2010 | 06:02 PM
PoorBoyBrian's Avatar
Body man extrordinair
also check the clevis that attaches the pedal to the master cylinder rod. my buddy's RB car had a stage 3 clutch in it and the stamped steel clevis folded over and was causing the pedal to not come back up after being depressed.
Brian
Facebooks
Old Apr 27, 2010 | 06:03 PM
finekey!!!! I just looked at your pic and it is exactly what i just said!!! h/o and ill circle what I am talking about!
Brian
Facebooks
Old Apr 27, 2010 | 06:08 PM
the part circled in red is supposed to be attached to what is circled in yellow
Brian
Facebooks
Old Apr 27, 2010 | 06:14 PM
no
Good eye! I didn't even see that. Mine bowed out a bit from the added stress of the heavy pressure plate. I'm pretty sure not having that bolt at the top contributed to its warping.
