ecu questions. rb25det s1/s2
Old Apr 26, 2010 | 12:50 PM
AWD4g63's Avatar
Default ecu questions. rb25det s1/s2
is there a huge difference in the rb25det s1 and s2neo ecu's? i have a s1 rb25det in my car but the ecu numbers come back as an s2 neo ecu. also the ecu does not have a diagnostic led or selector knob thing inside of it. is this normal for a series 2 neo ecu? the car seems to run pretty good. but this is my first rb25 so im just assuming its running normal. should i track down an s1 ecu or should i be fine with this one
Skyvia - The Best of Both Worlds
Old Apr 28, 2010 | 07:38 PM
180SX's Avatar
S2 ecus do not run a ignitior on the back of the coil cover... if you have one, then it is a s1 ecu.
martin
Old May 1, 2010 | 03:05 PM
AWD4g63's Avatar
well the part numbers on the ecu come back as an s2 ecu. but i have an igniter on the coil cover. and theres no diagnostic led in it either. so idk whats up with the ecu
Old May 11, 2010 | 02:20 PM
BluRRboSi's Avatar
35.5 psi, stock sleeves
s1.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
