tires rubbin
Old Mar 31, 2010 | 10:57 AM
jamesp65's Avatar
Default tires rubbin
So ya I have stock spec tires and they rub in the wells when I do u turns or reverse with the wheel cranked....clueless here any ideas?
Old Mar 31, 2010 | 11:02 AM
tuner1989's Avatar
Turn your shit, when it starts rubbing stop car go look. Slap forehead and fix what is rubbing.
Old Mar 31, 2010 | 11:04 AM
mewantkouki's Avatar
no
Old Mar 31, 2010 | 11:05 AM
jamesp65's Avatar
Did that, the tire is rubbing on the wheel well....not sure how to fix that is why I ask. Stock height as well if anyone is going to ask.
Old Mar 31, 2010 | 11:08 AM
jamesp65's Avatar
Whoever wants to be an ass can hit back now. Seriously if all your spare time is spent e-thugging then kill yourself. Anyway are there any valid ideas?
Old Mar 31, 2010 | 11:09 AM
no
What wheels?
What offset?
What size tires?
How many curbs has this car hit?
I'm also confused as to how your tires are rubbing your wheel wells at stock ride height unless of course you are using a sidewall of 90 or something or you have 20's.
240sx's didn't come standard with offroad tires.
Post a picture. I'm mindfucked right now.
Nobody's e-thugging. This thread is seriously retarded.
Old Mar 31, 2010 | 11:12 AM
jamesp65's Avatar
You see why I'm confused. When I say stock I mean I just got it off an older woman. Se wheels, stock ride height, and the tires that are recommended for the car. I forgot the size, bad memory.
Old Mar 31, 2010 | 11:14 AM
no
Are your splash guards installed correctly..? Are your struts blown? Is your tie rod bent?
Old Mar 31, 2010 | 11:17 AM
jamesp65's Avatar
Those are the kind of answers I was looking for. New struts, splash guards have never been removed I doubt, and I didn't even think the tie rod.
Old Mar 31, 2010 | 11:21 AM
no
Are you sure the tire is rubbing? Do you see wear in a particular spot or along a stretch of the tire? Is there wear on the fender from said rubbing? Do you smell burning while the tire is rubbing on the car? Do you hear the tire contacting the fender which is what is leading you to believe the tire in question is rubbing. Are you sure it isn't a belt squealing? Has this car been in an accident? Is the fender dented causing it to touch the tire?
