weird issue help
weird issue help
So I'm having a weird issue with my new coupe. So I thought it was my breaks dragging but now I'm not sure if that's it. I was driving today on the highway and hit the gas to get up to speed and basically nothing happened. So I just pulled back a bit and it started accelerating. When I got in my neighborhood I tried this again from a dead stop and seriously nothing happened. Anyone have any ideas?
I guess my clean new coupe has some demons.
First thing first I would replace your fuel filter spark plugs and all the normal stuff when you first by a used car..
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
so at WOT it bogged, but at say, half throttle, it went... right?
sounds like the same kind of problem that another TR guy is having...
start with the basics.
make sure your timing is right
see if the fuel filter helps.
if you have a buddy that has a good running car, borrow his fuel pump and see if that helps.
check your TPS and make sure that is right.
start with all of that and see where you end up
Yea my vert was doing the similar. After I adjusted the dizzy back where it was supposed to be and did a tune up it's a world of a difference
So I did my plugs and changed the fuel filter. Runs better but under 1k rpms full throttle does nothing. We tested the fuel pump its working just fine. Anyone have any other ideas?
