Little tricks you have learned on the way (CAR RELATED)
Old Mar 19, 2010 | 01:08 PM
Super Coupe's Avatar
Old school TR member
Default Little tricks you have learned on the way (CAR RELATED)
Lets try and keep this a legit thread.
Post up some things you have learned along the way while working on cars. Tricks/tips car and s chassis related.
Ill start off so you get the idea:
-Cheap cat litter to soak up oil/random fluids
-WD 40 if you forgot to wear gloves and need something to break down the grease on your hands (assuming you do not have other things) I do this a lot before washing hands with soap.
-Sawzaw is your friend
Old Mar 19, 2010 | 01:11 PM
Zenkijavier93's Avatar
pb blaster saves money!(for ppl who have rust up the ass)
Old Mar 19, 2010 | 01:14 PM
presidential's Avatar
OG Join Date: 6-15-00
Sell it before it becomes life consuming.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Mar 19, 2010 | 01:33 PM
sean1's Avatar
i has double turbo
if it has tits or wheels its gonna cost lots of money
my honda sounds like a lawnmower, because it is one.
Old Mar 19, 2010 | 01:37 PM
Bullitt_S13's Avatar
(O=O/--RPS13--\O=O)
^lol
fixed=sawzall
1. Invest in a soldering iron
a. Learn to solder
2. Buy a multimeter
a. USE IT
3. Download the damn FSM
a. Learn the wiring diagram
4. Use common sense, don't ghetto rig shit (don't have the "I gotta drive this out tonight no matter what" mentality.
Old Mar 19, 2010 | 01:38 PM
Epstein's Avatar
Retired
Tip #1: build the car you want, not the car that people tell you that you want.
Trick #1&2&3: If you suck at setting the cam timing on your motor, ziptie the cam sprockets to the chain. Removing the sprockets from the cams is much easier in the head, since the caps are holding it in place. It's just a 1" opened to hold the cam, and a 24mm to do the bolt. Use a deep 24mm and it will sit in the notch on the front of the head. This gives you tool clearance for the ratchet and helps brace the socket as you undo the 100ft-lb bolt.
Old Mar 19, 2010 | 01:50 PM
c89s13's Avatar
Break cleaner helps break down grease stains on concrete driveways
fender roller rental
shared_pm me for info
Old Mar 19, 2010 | 02:03 PM
flyspyder55's Avatar
when removing a pilot bearin without th proper tool:
1 wet tiny pieces of paper towel and shove them behind the pilot
2 repeat step 1 alot
3 take a small socket and extention just slightly smaller than pilot bearing hole and hammer into the hole
4 repeat step 1 as the paper compresses
5 pilot bearing pops out.
works great
another tip... cocain would have probably been a cheaper hobby than cars
Branden Berger
352-789-0006
86.5 toyota supra- 1jz never to be finished
01 mitsu eclipse v6 5mt chick car daily
98 honda accord ex- h22 swapped daily driver
Old Mar 19, 2010 | 02:07 PM
1337240sx's Avatar
^^^ also works with grease... and a bolt the same size as the pilot bearing
Originally Posted by Empire oh no. another ass hole 240...
Old Mar 19, 2010 | 02:13 PM
but grease is yuky
Branden Berger
352-789-0006
