Gas guage reading wrong
Old Mar 8, 2010 | 03:46 PM
Super Coupe's Avatar
Old school TR member
Default Gas guage reading wrong
Fuel sending sensor?
Old Mar 8, 2010 | 03:54 PM
MacGruber's Avatar
MaDe Of MoNeY
its probably just your float.. pull it out by removing the plate thats covering your gas tank and check to make sure its not bent or binding up or anything.. should be able to get one for pretty cheap.. if you have a buddy that will let you tinker with there car you can messure the signal that is being sent out by the float when its at full tank and comapair to yours to give you an idea on whats going on and if the sensor is bad or not..
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Mar 8, 2010 | 03:59 PM
Ya at a full tank it is reading a 1/4 under.
Old Mar 8, 2010 | 04:05 PM
MacGruber's Avatar
MaDe Of MoNeY
yeah i bet its probably the float just make sure nothing is bent or broke off in the tank..
Old Mar 8, 2010 | 07:29 PM
4wheeldriftS13's Avatar
February - Ride of the Month
Sounds like you have the assembly off somewhere, take it out of the tank and inspect.
Shit happened to me a couple times.
RIP Tim Aldrich
Old Mar 8, 2010 | 07:36 PM
^ This thing is stock, maybe something just fucked up.
Who cares, I have to go install the walboro anyways.
Old Mar 8, 2010 | 11:24 PM
JaxS13Racer's Avatar
Sold my sol for Silvia
Mine used to read under, but then I ran some Lucas through the tank and it worked like it was supposed to after that. Just sayin.
Old Mar 9, 2010 | 03:35 AM
Jr_SS's Avatar
S one 4
They tend to be off from the factory or get progressively worse as the vehicle ages. I've owned two nissan vehicles and the gauges in both never reach a full tank, but it'll drop below the E line before the light comes on. Im sure there is a fix for it, but I really don't want to go tearing into my gas tank unless I need to replace my fuel pump.
Old Mar 14, 2010 | 04:34 PM
ruffwhr2's Avatar
I had a similiar problem, when I filled my tank with gas it went to full, but when the gauge was showing empty actually had half tank of gas left (thought I was getting terrible gas mileage) first I replaced the level sender but samething kept happening. ended up being the fuel gauge itself. replaced the fuel gauge in the cluster and its been perfect since.
Old Mar 14, 2010 | 04:50 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
mine is all messed up to i think it's my gauge cluster thou lol just to lazy to tinker with it.
Drifting:
most fun you can have
with your pants on.
