sr20det
I have a 93 240sx with an sr20det, doing some work on it and i took out the bolt holding the oil line on top of the cams, should that bolt(circled in green) be a banjo bolt? Thanks
When you turn your car on, does it return the favor?
It looks like a normal bolt, if you've never seen it before. The head has a round/flat feature at the bottom. Just make sure to put the bolts back in the right place when you're done.
