JDM Primera motor
Guest
Posts: n/a
Originally posted by "Someone"
Originally posted by vtec_rex
What about intake manifold 91-93 is different from 94-96 I have a 94. Also all primera has 91-93 intake mainfold also will cruise control work and also how will the power steering fit too?
were can get a motor like this from?
1. power steering pump
2. throttle cable
3. cruise control cable (actuator assemly)
4. throttle cable bracket
5. brake booster to intake manifold hose
6. intake
You will also need to disable the EGR temp sensor with a 100K ohm resistor or else you will get a check engine light.
Also for the cruise to work you will need the upper throttle linkage from a 1991-1993 G20 or Sentra SE-R with cruise.
If you need an install hit me up at jwhitely2000@yahoo.com or PM me.
Good luck
Originally posted by Boosted Z31
i warn you an install will take 2+ years to complete
-B.J.F-
-B.J.F-
