[s13] Front control arm bushings question
Old Feb 8, 2010 | 10:04 AM
awebz's Avatar
Default [s13] Front control arm bushings question
is it possible to change all front control arm bushings without disconnecting tie rods?
how long would changing all front bushings (both sides) take aprox?
also does anyone happen to know if these are polyeurathane?
AutoZone.com | | Energy-Suspension/Control Arm Bushing - Front | FRONT C A BUSHING SET
ty
Old Feb 8, 2010 | 10:06 AM
Epstein's Avatar
Retired
Yes. Just unbolt the inner point, undo the sway bar end link, and pop off the ball joint. You can leave all the tie rod stuff alone.
All the Energy stuff is poly.
Old Feb 8, 2010 | 10:08 AM
LongFellow's Avatar
Please hold...
I would just take it off because when I did mine I had to burn the busings out then cut out the metal sleeve. Just save yourself the head ache and remove them replace the bushings then get the car aligned.
Team White Car 2010
Old Feb 8, 2010 | 10:12 AM
awebz's Avatar
ok I might actually just replace the tie rods with new at the same time because at least one seemed to have play. is this worth it?
Old Feb 8, 2010 | 11:18 AM
Epstein's Avatar
Retired
Tie rods shouldn't have ANY play. The play will increase very quickly until they become dangerous. If they pop out in a turn, you'll probably fly off the road.
Old Feb 8, 2010 | 12:20 PM
awebz's Avatar
ty sir! I will keep this in mind and double check them when changing the bushings
