Here we go again...Z32 Problem
Old Jan 10, 2010 | 08:32 AM
mewantkouki's Avatar
no
Knock, knock
Who's there?
Sensor
Sensor who?
Knock Sensor <- make sure it isn't cracked.
Old Jan 10, 2010 | 08:54 AM
AustinZ32's Avatar
...lost in thought.
If its the knock sensor, good luck with that. whole top of the engine has to come off.
if my car actually got voted ride of the month, id probably set it on fire.
Old Jan 10, 2010 | 12:43 PM
Mephisto's Avatar
Knock Sensor would be easy to diagnose, the ECU will spit out a code. I've had one go out and this doesn't sound like one. Have you checked ECU for codes? Also start the car and disconnect each coil pack to see if the idle changes to see if one is broke (or possibly narrow down a bad injector) Also ohm check the injectors. If you need a coil pack I have several that I will give up for $20.
Old Jan 10, 2010 | 03:45 PM
sameo2's Avatar
infiniti tech
Originally Posted by AustinZ32
Could be CAS, only giving out enough power to the injectors at idle, and on acceleration it may not be supplying it good enough.
^^ Negative,CAS control firing order ,Ecm control injector pulse.........check all 4 conection at the ignitor!knock sensor wont give you runing problem!!
Old Jan 10, 2010 | 03:55 PM
Moccia's Avatar
Yeah, I didnt think it was the knock sensor, already checked the codes givin me 555 so its not a sensor, imma pull the packs tomorrow morning. timing is 20 degrees off dead center correct?
Old Jan 10, 2010 | 06:26 PM
ZXTT's Avatar
A$$hole
15* btdc....I still have some coil packs from when you bought them so if u need one you know where they are. I got laid off so I'm just sittin around the house till I get bored and go back to work, so any time you wanna bring it by I'll take a look at it
Originally Posted by Automobile Magazine
The 300ZX Turbo is a dance; it's a song; it's rolling, roaring automotive art. There is no color that doesn't suit it. There is no mood-lifting chemical substance it can't replace.
Old Jan 10, 2010 | 07:27 PM
  #17 (permalink)
Moccia's Avatar
youre still living at the same house?
Old Jan 10, 2010 | 09:59 PM
  #18 (permalink)
ZXTT's Avatar
A$$hole
Yep same house.
Old Jan 11, 2010 | 05:38 AM
  #19 (permalink)
Clint's Avatar
keyboard hardass
I had a similar problem after getting my 120k service done, but he just forgot to tighten the CAS so it rotated out of timing.. good luck though
Offroading Spots near Tampa
Green markers = Pay spots
Blue markers = safe free spots
Red markers = not so safe free spots (possible trespass issues)
Old Jan 11, 2010 | 05:59 PM
  #20 (permalink)
Nycist's Avatar
NY Till I Die....
idk if you've done this yet, but make sure to check for a faulty fuel pump.
Originally Posted by Lime_Green_Hatch
$350,000 in 2 years... and all they had to show for it was some shitty hondas, lol.
R.I.P. Steven Daniel Berry a.k.a. Bush
