A little help...
Old Nov 17, 2009 | 04:10 PM
ChūkiS13's Avatar
Question A little help...
Recently whenever I give it gas the engine kind of bogs down... at first it's ok, but once I hit a certain point it just bogs down for a lil bit then it kind of picks up again. Any ideas?
Old Nov 17, 2009 | 04:40 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
fuel filter
spark plugs
wires
dizzy cap/rotor
water in gas/bad gas
tps(throttle position sensor)
Drifting:
most fun you can have
with your pants on.
Old Nov 17, 2009 | 04:50 PM
ChūkiS13's Avatar
Fuel filter and spark plugs are new... visually checked wires and they seemed ok... buying new gas tomorrow we'll see... i'll check the dizzy and tps thanks for the advice.
Old Nov 17, 2009 | 06:30 PM
Charles's Avatar
Senior Member
what they said, also buy some MAF cleaner and blast that out for good measure. That cured my "run like crap when cold" issue.
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old Nov 18, 2009 | 01:53 PM
ChūkiS13's Avatar
new gas, same problem... sprayed out maf, same problem... havent gotten to dizzy and tps yet...
Old Nov 18, 2009 | 04:39 PM
Xavier240's Avatar
Purple People Eater
u can come by and swap mafs to check ur problem if u want.
Purple heartbreaker
Lonely Hearts Drift Club
Old Nov 19, 2009 | 05:04 AM
ChūkiS13's Avatar
You available around lunchtime today or tomorrow?
Old Nov 19, 2009 | 12:13 PM
ChūkiS13's Avatar
Update... took off air filter and put a sock over the maf (ghetto I know) and the car ran perfectly fine... cleaned air filter and tried again... problem returned... bought new air filter same problem... think the maf is just completely bad?
Old Nov 20, 2009 | 06:18 AM
rhart's Avatar
Because race car…
I'm not sure if the sock method can give anyone 100% certainty but having a buddy with a spare MAF to swap should be your next step.
I've been following this thread because my car is acting the same way. Let us know if your MAF is bad when you find out. Swapping a MAF is easy stuff, but if this doesnt work you might look into cleaning the IACV, which can be a bitch (unless you have little hands like that guy on the Burger King commercial, LOL!!)
http://www.youtube.com/v/xu_bE7g2wqM...</param><param
If it has tires or boobs it's going to cost you money...
Old Nov 20, 2009 | 10:17 AM
Xavier240's Avatar
Purple People Eater
yea im available
Purple heartbreaker
