Rear brake question
Rear brake question
So, my rear passenger caliper is leaking and i need to either get an oem one or possibly upgrade. Are there any rear calipers that can be used with the factory rotors or a cheap swap that wont require the most money/ labor.
Im at USF and i dont have a jack so i cant take my wheel off to really see what the exact location of the leak is.
Thanks in advance, Garrison
1983 AE71 Corolla- 16v 4age... racecar
1993 D21 Hardbody- a/c, music... grocery getter
- Garrison -
Just throwing it out there, by the looks o your car you can make anything work on it.
- Garrison -
How do you know its your caliper leaking if you haven't taken the wheel off?
Get with a friend and borrow his jack. Determine where the leak is. Then start a "wtb" thread in Nissan classifeds. Cheapest solution to your problem.....
ok i'll try that. i just reached behind the wheel and felt the caliper, then pulled my hand back out and it was covered in brake fluid, so it was more of an assumption
- Garrison -
- Garrison -
