clutch fan options?
clutch fan options?
so im looking for a sr clutch fan but no one has an extra one laying around in orlando,
option 1 , would a ca fan be the same size and would fit?
option 2, can i run a ka fan or is it bigger, i think?
or option 3 , stop asking gay question and run some shyt nikkas!!
Yeah man fuck the clutch fan buy a e-fan.
www.Fabthis.com
Check out our blog and buy our products
Prestige Worldwide ... Wide..Wide....
www.Fabthis.com
you can use a KADE clutch fan, but it taps a pully, i ran mine on my SR for a while, all i did was shave off about 1/4" off the back of the blades...
now i'm running an OEM clutch fan, shroud, and condenser fan... only runs hot at the track, and even that is at OEM temps... hot for me i guess... Nismo tstat keeps it running cooler than OEM all the time...
He has dual flexalites and like 2 relays and its still drawing way to much current. I mean the relays could possibly be wired wrong I guess but I don't know. I'm with him though I <3 my clutch fans, I will always run clutch fans on SR... maybe clutch fan + electric fan but I've had electric fans fail to often, a clutch fan is your fail safe.
If fans are failing on you, quit buying garbage, way too many OEM cars run around every day with just electric fans and dont blow up instantly if something goes wrong. IF things are wired right you are gonna know it before any sort of damage is caused.
