WTF gauge cluster problem
Old Oct 21, 2009 | 06:11 AM
marble hatch's Avatar
i can has 30r plz?
Default WTF gauge cluster problem
Ok i rubbed through some wiring one night out sliding but didnt break any wires and my tach, speedo, and gas gauge reads wayyyy past full. So i taped everything up and ziptied it out of the way and it still doesnt work.. any ideas of what is going on?
(O=O/-180sx-\O=O)
Old Oct 21, 2009 | 06:37 AM
4wheeldriftS13's Avatar
February - Ride of the Month
reads past full? I understand the gas gauge, but tach and speedo?
If everything wasnt working i'd say you grounded off the cluster, and blew out a ground on the cluster. Ive done it before at Desoto.
RIP Tim Aldrich
Old Oct 21, 2009 | 11:09 AM
i can has 30r plz?
sry the tach and speedo dont work.. and my gas gauge reads wayy past full..
where should i start looking? under the dash? relays? fuse's? under the fender?
(O=O/-180sx-\O=O)
Old Oct 23, 2009 | 10:29 AM
Empire's Avatar
buildin' it
pull the cluster itself out and see if it looks burnt... from the few that i've dealt with, when that happens, the cluster itself is FUBARed....
Old Oct 23, 2009 | 02:45 PM
quicsilvia's Avatar
Weee!!
yep sounds like u killed ur cluster.. id pull it apart tho like empire said might find its not the cluster who knos
RIP Tim Aldrich
Old Oct 23, 2009 | 06:36 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
i have a sohc cluster just chillin in my shed.lmk
Drifting:
most fun you can have
with your pants on.
Old Oct 23, 2009 | 07:11 PM
Empire's Avatar
buildin' it
sohc cluster won't work for a dohc engine/chassis.... well, it will, but the tachs will need to be swapped... everything else will work..
Old Oct 26, 2009 | 04:07 AM
i can has 30r plz?
not exactly the ground circuit on the back of the cluster was burnt yes but along that circuit there is 2 screws so i took some 20 gauge wire and ran it to both screw to complete the ground circuit. BOOM SHAKALAKA everything works. thanks for the help guys and i hope this helps other people aswell
(O=O/-180sx-\O=O)
Old Oct 26, 2009 | 08:41 AM
quicsilvia's Avatar
Weee!!
be careful with that make sure u dont rub thru again or it will be ur car burnt to the ground
RIP Tim Aldrich
